I using xperia J from Last 3 Month, it working nice with only problem that it get switch off sometimes and need to re-start.
Please help why this happening
Does your unit power off at all when issue happens? No autoreboot?
Does your xperia overheat or there is a high battery consumption?
Does your phone power off by itself even in flight mode?
Does issue happen when unit is on stand-by?
How ofter does it happen?
Most likely this issue is caused by a app/process that isn't working correctly
Check if issue is the same starting the device in safe mode
