Need urgent help - please
amanchauhanoffi
Hi, I am using Xperia Z1 Compact from long time, earlier I was had only one problem which was "camera not available" error but I never complained about it cause it seems major bug with this series. but from past few days my phone is acting so weird it freezes a lot, and today what happened, My phone screen was freeze for 6-7 minutes, then finally when it get back to normal then I tried to restart the phone, then suddenly whole screen got black and an icon appeared in middle of the screen "it was a triangle with some weird tool and a big cross on it like this X" and it took a lil bit extra time to turned on. What does that mean is it normal or should I visit service center.
4 REPLIES 4
Thommo
Try performing a system repair using PC Companion as this will often fix issues - This will factory reset your phone and erase all data so best to backup before you begin
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the on screen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
Uliwooly
Don't forget to backup
ashishsingh007
I also saw that error. That's a big exclamation mark with some kind of progress bar and then phone restart again.
Question is what makes it happen. Why does a exclamation mark comes with some progress bar moving.
Thommo
Normally a system update or a corrupt system
