light sensor doesn't work
Mobin1
In diagnostics light sensor test the display doesn't fade why please help me
3 REPLIES 3
profile.country.RO.title
_alexdon_
When you test the sensor,if you cover it,you will get the message on.
alexdon
Mobin1
the diagnostics light sensor test says(Hold your hand over the upper part of the device the image will fade when the sensor is covered) even I hold my hand over the upper part of the device the image doesn't fade
_alexdon_
There should also be a message ON and OFF. Does it change?
alexdon
