help please XPERIA Z3 no power button
WaterDamagedZ3
ehllo!!! help please!!! my sony xperia z3 with my wet fingers was ok and no condensation and thing was wrong for like 3 hours!!!!! after den my z3 started vibrating and screen turn on so i checked it and then it stopeed vibration and i try to lock it and no LOCK!!!!!! My power button does not wrok!!! no screen on / off i pressed volume button and it shows like i would be holding the power button cuz it shows the screen power off restart take a screen shot. i pressed power button + volume up and this worked my device when off but automatically on!!!!!!! i also after press yellow button next to sim and it shut down but automatically on!!!!! NO CONDENSATION!!!!
all works but power button and some stupid vibration not like when typing that so big but some gentle . what to do!!!!! I NEED POWER BUTTON!!! Is there screen on off buttons to press?????>?? what can i do !!!! help all function work no problem but power .
the volume up recognizes it as im wanting to volume up and power button both!!! HELP :(((( im so sad this device so expensive and so gentle it was not submerged only wet fingers!!! not even ever rain !!
23 REPLIES 23
WaterDamagedZ3
Oh!! my god it stops working again the power button !!! :((((( Its in rise!! but the screen is on!!! i cant turn it off!! i hope rice will fix problem!!!!!!!!!!!!!
i open all flap and put rice in bowl and close it! is it ok how am doing it!?  how long stay xpeira z3 in rice?
Uliwooly
@WaterDamagedZ3
that's exactly how to do it, remove the SIM and SD cards, leave it for 2-4 hours
WaterDamagedZ3
it was in rice 6 hour and i took out and screen off i press power button and it work for few hours and den again started!!! can it be hardware!???? i not drop my fone and i took out sim and white marker was white and button sometimes work sometimes not (mostly not but sometimes after lot pressing it it works for 4-5 presses)
:((( what to do !
WaterDamagedZ3
hey you think this possibly software issue or 100% hardware !!
WaterDamagedZ3
Hello i plug fone into computer and power on pc companion and update and press fix phone in blue writing it start doing some actions and then i agree to the google account and then press 2 times i agree to lose of data and then some donload start jn pc companion and then phone works properly the button. Lets hope this will be ok all time now.
Uliwooly
@WaterDamagedZ3
I was about to suggest PCC, if you experience the same contact your Local support
WaterDamagedZ3
Hello thank's for reply.  I plug fone in computer i did not repair i wanted but after it went to installing some things to my pc i started working so i unplugged and it still working and i did not has tp repair and lose data i hope it will not brake again!!!!
Uliwooly
@WaterDamagedZ3
Keep us updated
emk
I wonder what happened next, it seems like a faulty phone and maybe drops of water get into the phone through the switch button
Uliwooly
@emk
It could be due to wear and tear or something else, I am intrigued to find out the resolution on this case.
