HELP! my z1 compact started to overheat + battery drain after dropping
nars_one
i accidentally dropped my z1 compact on a wooden floor. hitting the floor i think sideways cause there's a dent on the floor but no dent on the phone. a day after it started to overheat with battery draining fast. is it possible my the battery was damaged after fall? should i have it checked?
2 REPLIES 2
Phy
Legend
Legend
Yes, that's a good idea. You can go ahead and contact Sony Xperia Support
http://www.sonymobile.com/global-en/support/contact-us/
Uliwooly
It does seems like a hardware issue, but if I were you I would repair the phone with PCC and check again but do follow @Phy 's advice
PC Companion (PCC)
Bridge (for Mac)
