I used Sony MDRXB950AP headphones with my Xperia E3....it doesn't give the required output...i tried on iPhone 6s it was giving out awesome sound and beats....again tried on Xperia SP but same issue...are the Xperia devices at fault or the headphones???
Xperia (and most android devices) will not let you go to full volume unless you accept a warning message that it might harm your hearing. Did you see and accept this message?
Does the same thing happen if you use these headphones with another Sony phone? It sounds like it might be the headphones that are faulty but to make sure you should try with another Sony phone just to make sure.
This warning message is made off long before...I listen in full volume...
Actually these headphones get the perfect powerful bass on iPhone 6...as dancing in a club....the bass gets a bit lowered on any Xperia device for the same song...tried Xperia E3 and SP....
Volume output on this model is very low compared to Iphones, Ipods or even ZTE. Maybe there is a trick at system level I dont know yet how to fix it, but this is ridiculous issue that Sony must fix soon.
