Flash problem
abbas_farhan
Visiteur
Flash problem
i downgrade my phone from 4.4.4 to 4.2 using flashtool. after completing flash succesfully i turn on my phone but the phone shows the welcome screen and shutdown it and automatically my phone turned on and again do the previous work. It worked continuously. I can't use my phone. Now what can i do??
Thank you everyone.
1 RÉPONSE 1
Thommo
Try performing a system repair - This will factory reset your phone and if successful leave Flashtools alone
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the onscreen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
