Charging problem
GagoFKRAD
Charging problem
Hi, before I start, I must say that my english lenguage is very bad, so I'll hope that you'll understand me Grinning_Face
When my phone is plugged to the charge, my display somethimes start to shakes and flashing. it takes until turn screen off. that begin to appear to me when I instal new version of software.
2 REPLIES 2
Thommo
Try performing a system repair as this will often fix issues after an upgrade - This will factory reset your phone
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the onscreen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
GagoFKRAD
Nothing... My problem not fixed!
Tags (1)
