After upgrading to JB on my Xperia P, it was actually working smoothly. After a few weeks the phone keept turning off 10 times a day because battery level was at 0% and I can reboot the device after shutting down. It will display a battery percentage that's not correct between 75-14% and it will carry on doing this till the phone is charged completely or charging. In fact this has happened 2 while writing this complaint.Battery Percentage isnt indicated properly o the phone thinks battery is dead
The album app will only display photos after boot till you only clear data in settings. And after every like 8 hours I need to clwar data again.
The phone app will still ring after taking the call resulting in missing the call.
Making a call is impossible cause the com.Sony......phone keeps craching.
Performance is really bad and the home launcher just love craching.
I've done a repair, factory data reset, restored older settings, and cleared the sd card.
I haven't played with developer options or let the phone drop I such a way to have affect with the battery.
Performance has gone way down.Apps freeze often.And often the phone needs to be forced restarted.
I also have Xperia P.Unfortunately,it has never been fuly optimised for better performance,better battery life and many more.But you can try from time to time to remove apps you do not use,try not to use battery savers,task killers.Restart the phone often and sometimes even force restart(power button+vol up until the phone vibrates).
ive tried evrything... with no change
I am sorry,sony has announced the end of support for many devices including P.Take a look.
