Sony xa1 ultra yeni aldığım telefonun ekran da Mavi ısık zararından engellemek için gibi ekran görüntüsü sarımsı nasıl cözebiliriz
Sony xa1 ultra new how I get the screen of the phone to prevent the blue light from the screen as well as how to fix the screen image yellowish
gt
Sony mobile garantisi varsa kvk bakıyor yollayabilirsin
If you have Sony mobile warranty, you can send kvk
gt
Kvk gönderdim yazılım güncellemesi yapılıp geri verildi sorun aynı devam ediyor
Kvk sent the software update done and the problem continues the same
gt
Please write down the note that the problem does not solve the problem.
Tekrak gönderin sorun ekranda diye not yazın.yazılım sorunu çözmedi diyin
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
Hello everyone and I'm sorry to hear about this.
Your posts has been translated to English as this is an International forum, so please post any replies in English.
@mehmetsahin41, is it only in certain applications the screen is yellow and is it the entire screen, or only parts of the display?
If you haven't done the display test that be found in Settings > Support > Xperia tests > Display, I would recommend that you do that, but if there is no change, get in touch with your Local support team so they can arrange a repair for you.
@Selman96, get in touch with your Local support team and they will arrange a repair for you.
Feel free to keep me posted!
