Ring volume
Ring volume
После обновления, на главном экране перестала регулироваться громкость звонков и уведомлений. Вместо этого увеличивается громкость мультимедиа.
After the update, the volume of calls and notifications was no longer adjusted on the main screen. Instead, the volume of multimedia increases.
gt
1 REPLY 1
Jonas
Master
Hi @Николаус, welcome to our forum!
Your question has been translated to English as this is an International forum, please post any replies in English.
In Android 9.0 (Pie), the volume keys will only adjust the media volume. This is different from previous versions of Android, where ringtone volume was the default setting. There is no way to change this setting in Android Pie. However, there is a toggle button for the three ringer modes just above the on-screen volume slider, which lets you turn the ringer off and on with a single tap. During calls, the volume keys will adjust the speaker volume for call audio, and the on-screen volume slider will show an additional column for this.
There may be third party applications that allow you to change the mapping of the volume keys.
I hope that answers your question! Slightly_smiling_Face
