Problem: sequence of three beeps.
Atlante1
Model Xperia Xa2 Plus in which three beeps sound every six seconds, as if it were a system warning Does anyone know what it may be?
Problema: secuencia de tres pitidos.
Modelo Xperia Xa2 Plus en el que suenan tres pitidos cada seis segundos, como si fuera un aviso del sistema ¿Alguien sabe a qué puede deberse?
2 REPLIES 2
Uliwooly
@Atlante
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
That seems to be a notification or alarm, does it happen all the time or at specific time? has it happened more than once?
profile.country.PL.title
MickeyPlus
This is a roaming warning
