3 Months of using this and most of the bugs are still there
These are the bugs:
1.] Camera app sometimes shows a unknown error
2.] Phone randomly freezes sometimes
3.] Still now RAW support, please sony, just add it (By that i mean full or limited mode of the camera2api)
4.] Both wifi and cellular drop from 3 bars to 1 bar sometimes.
5.] Wifi randomly disconnects.
6.] Overheating issues, possible solution- slow down the cpu clock when it reaches a certain level of degrees. Camera produces heat really quickly.
(battery wasn't charging, just some regular 1080p30fps filming)
7.] Camera's color tone goes to greenish in low light however it can be adjusted via brightness and color adjustments (hope it would do that automatically)
8.) Bluetooth issues (added by @Pol63)
10.] Battery percentage sometimes drops in a 2% adjustments(example: instead of going from 25 to 24, it goes from 25 to 23 skipping a percentage)
9.) Sometimes the mobile data signal just completely drops out (reported by other users)
11.) Not all calls received (reported by other users)
Im glad to see Sony watching this topic
I got it too. H3113 here. No ideea if it fixed something or just the security updates.
Can anyone who has the XA2 H3113 whether you use the pre installed messages app or not if you could tell me if you have the delivery report option under the advanced setting?
Yes cob, I have that option. U. K.. Tesco mobile.
@Niko69 wrote:Yes cob, I have that option. U. K.. Tesco mobile.
Can you confirm which phone you have?
Are there any virgin mobile users here who have the XA2 H3113 phone?
Same phone, tesco mobile.
I have it on mine. Using default messages app from Google.
@davidhozic wrote:he should reinstall the apo because its google's
You can't reinstall the app, all you can do is uninstall the updates then update it again, this is due to it being pre installed when phone was purchased.
Tried it anyway and still the Get SMS delivery reports doesn't appear in the apps advanced settings.
I have same issue with camera on Xa2 ultra not working. One week old when it started and rairly will the camera work. I have reset phone three times now and have used phone about six weeks. No ryme or reason when it will work, but when it does actually start if I select any options it errors out. Most often I just get this Error when I start camera:
Error
Cannot start camera.
Restart camera or device
