that can't be done, you might want to look for other apps that have some sort of stealth mode
hide number? as to hide your phone number whenever you make a call?
as for notifications, open the app > settings > notification settings
Someone from your phonebook, so that nibody would know whom you are calling or texting, without intention of blocking it
With regards to message app and phone nos, how to hide and remain active
Hi @Jumar, welcome to our forum!
If you want to hide your number for outgoing calls, you can have a look with your operator and see if there is a code that you can type before the number to make it hidden, or you can enable the setting for this in the device by opening up the Phone application > tap the three dots in the top right corner > Settings > Calls > Additional settings > Caller ID.
If you want your number to be hidden when sending a text message, you will need a third party application for this as @uliwooly mentioned, or you can check with your operator if they can assist you with this.
I hope that helps!
