Charging issue
crismatos
Charging issue
My cell phone will not charge
Hello
My cell phone is the Sony xa1 ultra and has been presenting a serious problem of uploads.
I put the charger and I can not charge it if I do not attach an object to the tip.
It goes up to 58%, after all day.
What should I do?
Meu celular não carrega
Olá
Meu celular é o Sony xa1 ultra e vem apresentando um sério problema de carregamentos.
Coloco o carregador e não consigo carregar se não prender na ponta um objeto.
Ele vai até o 58%, depois do dia inteiro.
O que devo fazer?
2 REPLIES 2
Uliwooly
@crismatos
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
I'm sorry to hear about your issue, have you tried:
tested different wall chargers and/or cables?
shutdown the phone > charge it ?
Findtime
I had the same problem recently. It was a broken charge port.
