Nuovo firmware TV versione 6.7205 (2016-2019)
Guybrush88
Membro
È stato rilasciato un nuovo aggiornamento per i seguenti TV:
  • KD-55AF8
  • KD-65AF8
  • KD-55AG8
  • KD-65AG8
  • KD-55A1
  • KD-65A1
  • KD-77A1
  • KD-50SD8005
  • KD-49XD7004
  • KD-49XD7005
  • KD-55XD7004
  • KD-55XD7005
  • KD-65XD7504
  • KD-65XD7505
  • KD-43XD8005
  • KD-43XD8077
  • KD-43XD8088
  • KD-43XD8099
  • KD-49XD8005
  • KD-49XD8077
  • KD-49XD8088
  • KD-49XD8099
  • KD-55XD8005
  • KD-43XD8305
  • KD-49XD8305
  • KD-43XE8004
  • KD-43XE8005
  • KD-43XE8077
  • KD-43XE8096
  • KD-43XE8099
  • KD-43XE8396
  • KD-49XE8004
  • KD-49XE8005
  • KD-49XE8077
  • KD-49XE8088
  • KD-49XE8096
  • KD-49XE8099
  • KD-49XE8396
  • KD-55XE8096
  • KD-55XE8396
  • KD-55XE8505
  • KD-55XE8577
  • KD-55XE8588
  • KD-55XE8596
  • KD-55XE8599
  • KD-65XE8505
  • KD-65XE8577
  • KD-65XE8588
  • KD-65XE8596
  • KD-65XE8599
  • KD-75XE8596
  • KD-49XE9005
  • KD-55XE9005
  • KD-65XE9005
  • KD-75XE9005
  • KD-55XE9305
  • KD-65XE9305
  • KD-75XE9405
  • KD-43XF7596
  • KD-49XF7596
  • KD-55XF7596
  • KD-65XF7596
  • KD-43XF8096
  • KD-49XF8096
  • KD-55XF8096
  • KD-60XF8305
  • KD-70XF8305
  • KD-43XF8505
  • KD-43XF8577
  • KD-43XF8588
  • KD-43XF8596
  • KD-43XF8599
  • KD-43XF8796
  • KD-49XF8505
  • KD-49XF8577
  • KD-49XF8588
  • KD-49XF8596
  • KD-49XF8599
  • KD-49XF8796
  • KD-55XF8505
  • KD-55XF8577
  • KD-55XF8588
  • KD-55XF8596
  • KD-55XF8599
  • KD-55XF8796
  • KD-65XF8505
  • KD-65XF8577
  • KD-65XF8588
  • KD-65XF8596
  • KD-65XF8599
  • KD-65XF8796
  • KD-75XF8596
  • KD-85XF8596
  • KD-49XF9005
  • KD-55XF9005
  • KD-65XF9005
  • KD-75XF9005
  • KD-43XG8096
  • KD-43XG8196
  • KD-49XG8096
  • KD-49XG8196
  • KD-55XG8096
  • KD-55XG8196
  • KD-65XG8096
  • KD-65XG8196
  • KD-75XG8096
  • KD-43XG8305
  • KD-43XG8388
  • KD-43XG8396
  • KD-43XG8399
  • KD-49XG8305
  • KD-49XG8377
  • KD-49XG8388
  • KD-49XG8396
  • KD-49XG8399
  • KD-49XG9005
  • KD-100ZD9
  • KD-65ZD9
  • KD-75ZD9
Il changelog riporta le seguenti modifiche:
  • Risolve un problema a causa del quale il TV si riavvia in modo casuale
Ecco il riferimento alla pagina di download:
https://www.sony.it/electronics/support/software/00262498
13 RISPOSTE 13
Marino.Manolo
Grazie.
RobbyB
Nuovo
Qualcuno l'ha già installato ? Funziona bene ? Sapete quando verrà proposto come aggiornamento automatico, senza forzarlo con chiavetta ?
sonysta
Campione
@RobbyB
E' gia" proposto" come aggiornamento automatico ma andando a scaglioni chissa quando toccherà al tuo TV...e NON è una "forzatura" aggiornarlo con chiavetta USB è solo un pratico sistema per anticipare i tempi.
RobbyB
Nuovo
Pensavo che iniziassero a distribuirlo come aggiornamento automatico solo dopo un certo periodo di prova, in modo da non avere centinaia di chiamate all'assistenza in caso di bugs.
Per i telefoni di solito fanno cosi.
Magari nel week end provo ad installare... mi sarebbe piaciuto avere un feedback da qualcuno che l'aveva già provato.
Grazie
sonysta
Campione
@RobbyB
Quando lo rendono disponibile è già quello definitivo e già testato quindi sia in automatico che via USB non cambia poi si sa, qualche bug o qualche problema alla lunga potrebbe saltar fuori ma questo è normale...non c'è miglior test che distribuire un nuovo programma per trovare con migliaia di utenti le eventuali problematiche anche perchè è impossibile sapere il tale TV con cosa e come viene usato con altri apparecchi.
Marino.Manolo
@RobbyB un problema potrebbe presentarsi ad esempio a causa di un'App che tu hai installata ed altri no, oppure a causa del collegamento con periferiche o dispositivi che tu hai ed altri no, quindi è possibile che un Utente ti risponda: installa pure, ma nessuno però ti garantisce che per la tua configurazione qualche "noia" non possa saltare fuori, troppe le variabili.
RobbyB
Nuovo
Certo, ovvio che non c'è nessuna garanzia. Ricordo che una versione precedente aveva dato problemi alla connessione con le soundbar. In questo caso il feedback secondo me è molto utile, perchè se ho una soundbar, magari aspetto che esca una patch successiva.
Marino.Manolo
Lo posso comprendere, ma le variabili restano comunque troppe, il problema potrebbe non presentarsi con la Soundbar che hai tu oppure si può presentare solo con quella che hai tu, un Firmware successivo potrebbe sistemare la questione ed introdurre un problema diverso, solo per la tua configurazione oppure per tutti a prescindere...
Purtroppo i rischi negli aggiornamenti ci sono sempre, può però anche andare tutto benissimo.
Se vuoi aspettare aspetta, ma è un'illusione sperare di sapere se un aggiornamento creerà problemi o meno per la propria configurazione.
A volte poi alcune "noie" introdotte da un aggiornamento si risolvono con un ripristino che riscrive il Sistema.
Andy48
Esploratore
installato da pochi giorni, perchè ogni tanto mi resettava, x adesso nessun problema speriamo duri nel tempo
