XM3 Headphones no longer Noise Cancelling
Crewood
Over the last couple of weeks, my XM3 headphones no longer seem to be 'noise cancelling' in as much as I can hear other people in a room talking which has never happened before.
Normally, when I wear the headphones and turn them on, there has always been a noticeable 'quietening' after a second or so and this no longer happens.
Any advice or help would be greatly appreciated.
12 REPLIES 12
HannahEd01
Hi Crewood, could you confirm which one you have? the wf or the wh?
Also, what makes you say that they don't cancel noise? What are the noises that you still hear?
Crewood
Thanks for the reply Hannah, really appreciated.
The headphones are the Sony WH1000XM3 model and I can hear people talking in the same room as I'm in while I'm listening to the TV. This has never happened before.
Crewood
Up until recently, while wearing the headphones, as soon as I turned them on there was a noticeable quietening with a second or so. This is no longer happening.
HannahEd01
Crewood
Thanks for the links Hannah, really appreciate all the help. If it's OK, I'll give them a try and post back if there's still a problem?
Cheers
Mike
HannahEd01
Hey Crewood, it's really a pleasure to help! Of course, take your time and reply whenever you can. :slight_smile:
Crewood
The Reset seems to have worked Hannah. Thank you for all the help and advice, it is really appreciated.
Regards
Mike
SkyNet404
Specialist
Oh, glad to know that! Maybe you should mark the answer to that other people can find it easily, cheers.
Crewood
As an update, the same problem has happened again only this time re-setting the headphones as not sorted the fault. I also tried step three for initialising by pressing both buttons for 7 seconds until the lights flashed blue. This has not helped either. I can clearly hear people talking in the same room while wearing the headphones in the noise cancelling mode.
The final step says "If the headset does not operate correctly even after initializing, consult your nearest Sony dealer." Can anyone please advice where I would look to find this please?
