Hi. Is the Bluetooth Sony PS-LX310BT record player compatible with the Sony HTA7000 7.1 soundbar? I want to be able to play the record player thorough the soundbar wirelessly. Does it work? Many thanks Wayne
As the soundbar supports a Bluetooth connection, yes you should be able to connect the record player to the soundbar.
Cheers cocker
