WH-1000XM3: Same device, but different OS. Unable to connect without pairing anew
eugene337
Hey
I have following setup:
iMac 27" 2019
First OS: OS X Monterey 12.1
Second OS: Windows 11, installed via bootcamp
Headphones info from bluetooth section in OS X:
  WH-1000XM3:
  Address: 38:18:4C:BC:CE:61
  Connected: Yes
  Vendor ID: 0x054C
  Product ID: 0x0CD3
  Battery Level: 100%
  Firmware Version: 4.5.2
  Minor Type: Headset
  RSSI: -46
If connect headphones to OS X, all works fine.
If restart and use Windows 11, I able to connect headphones via bluetooth
If restart and use OS X, unable to connect headphones. Only if delete it and add again.
Then, moving to Windows 11, same situation there. I need delete headphones first and only then add.
Same situation was with Windows 10
I guess problem what headphones remember iMac Bluetooth adapter ID, and disallow to add duplicate bluetooth adapter.
How to use headphones on each operating system, without adding them anew?
1 REPLY 1
HannahEd01
Hey eugene337, try the list of the steps here: https://helpguide.sony.net/mdr/wh1000xm3/v1/en/contents/TP0001703177.html
Test after each step.
