I like this product a lot but I find the battery life really disappointing.
I fully charge the battery for 2 hours. I switch the power off and don't use it for a day or so. When I switch it back on the battery has been draining down.
How can the battery drain down if it is switched off?
Hey @Edmund, there seems to be a battery problem. I came across this link with some tips on how to reduce battery life: https://helpguide.sony.net/dmp/nwe390/v1/en/contents/TP0000892573.html & https://helpguide.sony.net/dmp/nwe390/v1/en/contents/TP0000892574.html
You can also try resetting the Walkman and check again: General Settings - Reset/Format - Reset all settings.
Hope it works.
