Sony SRS-XB30 will not Charge
paulaxon
I have an sony SRS-XB30 that will not charge, I have changed the Charger twice and it is still not work no light nothing can anyone help please
4 REPLIES 4
Mick_D
Hi @paulaxon, welcome to the Community.
Normally it's just the charger needs replacing; it could also be a fault in the charger port on the device, and while that's much less likely, it's the only other thing I can think of.
Could you confirm the other chargers you tried were new/unused?
Cheers
Mick
Win_88
Specialist
Hi paulaxon,
This could also be just a glitch within the speaker. I would suggest resetting it as described here.
If the issue remains, I think that it should be sent to Sony service centre.
Win_88
Charlievic02
Charlievic02
My speakers will not charge it turns on then the light flashes twice then turns off do you know what’s wrong with it ?
Tags (1)
