Hi!
How do I remove the google search widget from my home screen?
All other widgets can be deleted, only this cannot be moved. Thanks for the reply!
From what I can see, most users replace the launcher with nova and then build their own style of custom launcher using that.
Some results certainly look impressive.
Hi @baloghrobcsi, Have you tried holding and dragging the widget itself to remove it? , also deactivating the google app might work.
