How do you turn on lcd display, just purchased today
Hey, the display should be working fine when you try to change the settings on your boombox, like when you press on the CD button it should recognize CD, if you are playing a track it should state the number of the track you are playing as well the duration. So if there's nothing showing on the display, check if you have the boombox powered on or not.
