head unit/cd changer
SOLVED
profile.country.en_GB.title
bobcwf
what cd cangers are compatable with a WX-C570R as a head unit?
1 ACCEPTED SOLUTION
Accepted Solutions
Drumzman
Hi bobcwf,
The CDX-656 is one of the newer varirty of CD changers with the sony BUS connector and the phono audio connectors, so I reckon this should do nicely! :slight_smile:
7 REPLIES 7
Drumzman
Hi bobcwf,
You should be OK with any of the later generation CD changers - by later generation that would be anything that was connected to the head unit with phono plugs for audio and with a data connection cable that Sony used to call unilink I think.  Prior to this, the old A series CD changers used a round multi-pin DIN connector lead only (that did both audio and control functions) - this would not be compatible.
If you've got a CD changer model number in mind, I might know which category this falls into and therefore whether it would work with your head unit or not.
Hope that helps?
bobcwf
thanx for the reply been offered a sony 656 unit will that be ok?
Drumzman
Hi bobcwf,
bobcwf
once again thanx for info
tazbirl
hi i have a sony cdx-r450 head unit and want to know which cd changers would be compatible with it???
SloopJ
I have the same problem, my head unit was stolen from my vehicle and I’ve been looking for a replacement. There’s loads of Sony front panels on EBay, but I’d like to know which front panel would be suitable for my Sony cdx-gt530ui.mp3
Piscie
Hi @SloopJ, have you checked EET for spare parts? On 01932226677 or https://www.youritdelivered.com/contact-us/
