I have a problem with my FE41S and the intel pro wireless 3945abg card.
sometimes when I suspend, or hybernate my vaio the card won't work when I restart
The worst is that this thing appens even when I work: suddenly my connection disappear: hardware manager shows my card correctly, but the little red light near the bluetooth led is shutted off. then if i hybernate at restart the card is still not working.
I have controlled in event viewer and I receive this message every 4-5 seconds maybe is something about this problem
"Nome registro: System
Origine: NETw4v32
Data: 04/08/2007 20.05.47
ID evento: 5005
Categoria attività:Nessuno
Livello: Errore
Parole chiave: Classico
Utente: N/D
Computer: vaio
Descrizione:
\DEVICE\{CC5500FC-94E9-4112-AFA7-24F9C99A9CDB} ha incontrato un errore interno e l'operazione non è riuscita.
XML evento:
\Device\NDMP27
someone may help me please?
Other computers with xp or ubuntu does not have any problem so is not access point dependent.
thanks in advance.
rkappa
Hi rkappa,
Vista and wireless connections seem to cause countless problems. Hopefully this is something that will be addressed in Vista SP1.
Are you using the latest Intel wireless driver? The file causing your problem - NETw4v32 - is an Intel file so updating the driver may help.
Intel® PRO/Wireless Drivers-Only for Windows Vista* [V11.1.1.0_VT_DRIVERS.ZIP]
Also check to see if the Default Gateway IP is being lost if you are using DHCP - there is a Microsoft Hotfix KB933872
KB933872
Sorry I can't think of a simple solution.
