Hello,
My VGN-FE41E changes it's own resolution to 1024x768 after recovering from hibernation, which makes the screen look not as clear as it should. When i reboot the system, everything is OK again.
Also, I can't change the display's resolution in the classic view of the Control Panel, the option just isn't listed. In Category-view however, the option is available.
The system is running the original Vista-installation (Home Premium)
Are these problems possible to fix with a Sony- or MS issued update?
thanks in advance,
m.schr
Welcome to ClubVAIO
The problem that you have descibed has a nice simple fix.
Download the following and install:
BIOS Update
Nvidia Graphics Drivers
great!
thanks for your fast reply!!
If that doesn't work, there is a Sony Patch available for this specific problem. Download it from here: -
http://www.vaio-link.com/cbcdl/7.15.10.9813a.zip
Installation instructions are in the .zip file.
Thanks, but updating the nVidea-drivers worked just fine.
