hi, kindly assist me in finding solution to how i could get my audio back from my vaio VGN-FS215Z. the system crashed and on re-installing the drivers, the sound does not come on [email protected]
Hi abundantly blessed,
Do you have any error codes or icons in Device manager > Sound, video and Game controllers?
To go to device manager click start > Run and type in devmgmt.msc and then press OK..
Or does a system restore to a point before your system crash resolve your sound problem..?
Right click my computer>properties>hardware>device manager>sound,video and game controllers and have a look at the tree by clicking on the plus icon. If any of the devices have a exclamation mark next to them then right click>update driver. this will reinstall the correct driver either from the onboard drivers in windows or the net. If this doesn't work then try a system restore to a time before the crash.
Hi, I have the same problem on my vaio vgn-fe31h. THe computer can play system sounds , but no other audio. the strange thing is , when i switch computer on, as it is booting up ,it will play audio, until booting up has finished then it wont! It has gone like this before but after a day or so sound returned. THis time it hasnt. According to the sound and audio section on control panel, i have no audio driver installed, but this cant be the case! also according to this, all devices are working properly
Ive tried doing system restore. When this happens , audio returns. HOwever Mcafee tells me computer is not protected and needs to fix problems- when problems are fixed audio is gone again!
can anyone help?
Many things
Lance
