Attention VGN-FZ21Z users and SONY!! Problem with Sound Card
herbmead
I am having problems with my sound card. It can not be found and I get the Error Message: “This device cannot start. (Code 10)”
Has anyone had simmilar problems?
Any suggestions to fix it?
Thanks.
George :slight_frown:
1 REPLY 1
rich912
Contributor
Hi George and welcome.
“This device cannot start. (Code 10)” usually means that you have a bad, missing, or incompatible device driver. This may be the result of installing other audio devices.
Open Device Manager and look for the device – it may be listed under Sound, Video and Game Controllers (with a yellow warning triangle) or as an Unknown Device.
Right click the device and select Update Driver.
Select ‘Browse my Computer....’
Next ‘Let me Pick from a List...’
Click ‘Have Disk’ and browse to the location of your Audio drivers – possibly C:\Drivers\Audio. If not you can download from the Support site – click Support at the top of this page.
Select the Setup.ini file and continue. Hopefully this will install the correct drivers...
Go n-éirí an bóthar leat
