6600 Upgrade on PCV RX1 : Problems
Olivier_RX1
Hi all,
i've changed my old Graphic card (Geforce 2 mx) on my PCV RX1 for a non-GT 6600.
I need to connect it at a molex, and i tried yesterday :
- After reeboot, mouse stopped to work
- Power supply got hot quickly
Of course, i've deconnect my Molex cable to avoid explosion :smileygrin:
What can i do ? Can we change power supply on this computer ?
Thx
8 REPLIES 8
profile.country.en_GB.title
kee-lo_
It might be hard to change as it's a non-standard power supply :slight_frown:
Olivier_RX1
Can i Change case + Power supply with all my actual components ?
I'd like to keep my Vaio case, but if it's the only solution....
kee-lo_
Hopefully you could, but it might not screw in well to the board.
profile.country.de_DE.title
seb21__
Mmmh, give it no possibility, to use the Power supply extern.
I think you need only a normal Power supply and cables they are long enough to reaching the PC components.
True, a VAIO with an external Power supply are not really nice. But I think that is a possibility. (tell me, If I'm wrong)
Olivier_RX1
I don't know external power supply. Do yo have an example ?
Thx
seb21__
ROFL
You need a Power supply like this one .
and cables like these .
You must dis-connecting the Sony Power supply and connecting the new power supply with the components in your VAIO.
I think a VAIO PC use the same cables like a standart PC.
kee-lo_
Euuuugh that would be ugly
seb21__
True, but it's the only possibility:smileysad:
