This issue has suddenly appeared for no known reason. Can anyone advise how to remove this annoying little interference? Many thanks for reading and considering.
When playing back a TV programme recorded on the HDD, a greyish transparent on-screen band displays across the top 3-4 inches of the TV screen that obscures viewing throughout the whole of playback. Within this band appears the HDMI symbol followed by the text "HDMI1 Recorder 1 (HDD/DVD)".
Any ideas?
AJ
Solved! Go to Solution.
This has nothing to do with the recorder. If you are using a Sony TV set (by the dimension of the band it seems quite hold) you just have to press the info button (top left on the tv remote) twice: it will disappear.
You are a gentleman sir and I am a numptie!
Many thanks for solving this little puzzle, regards.
AJ
don't worry, it happens quite often, this is the reason why it tooks 2 seconds to understand your problem
