Partagez votre expérience!
I keep losing BBC i-player on my S570 blu ray (it freezes and reloads) several times on a lot of progs, can anyone help please??
Just iPlayer or other services too? How are you connecting your device to the web?
I am connected wirelessly and I only have this problem with the BBC iplayer and thanks for replying Eduzzel. BRIAN.
Message was edited by: brian.hinchcliffe
Have you tried hardwiring the device to the router to see if that makes a difference. Drop out is likely down to wireless reception - could be a black spot or something.
Try running a length of ethernet cbale directly to the device to see if it improves. If it does, then I would switch to homeplugs or see if you can improve your wireless signal from your router..
Thanks
