YouTube HDR content is finally available!
You will find a playlist here. However, these clips will be played as SDR on Sonys for now.
With youtube-dl you can find vp9.2 encodings for those clips:
330 webm 256x144 144p60 156k , vp9.2, 60fps, video only, 2.38MiB 331 webm 426x240 240p60 256k , vp9.2, 60fps, video only, 3.87MiB 332 webm 640x360 360p60 485k , vp9.2, 60fps, video only, 7.35MiB 333 webm 854x480 480p60 909k , vp9.2, 60fps, video only, 13.83MiB 334 webm 1280x720 720p60 1991k , vp9.2, 60fps, video only, 28.18MiB 335 webm 1920x1080 1080p60 3201k , vp9.2, 60fps, video only, 49.70MiB 336 webm 2560x1440 1440p60 11166k , vp9.2, 60fps, video only, 170.23MiB 337 webm 3840x2160 2160p60 20122k , vp9.2, 60fps, video only, 335.45MiB
Those are webm however which the native Video app won't play.
We will see whether we will get support for it soon, even for the early 2016 models with the old MediaTek SoC from last year. At least Sony promised that back at CES:
@zer0ner0 wrote:
@rooobb wrote:Just released version 2.04.05 of the standard app on tv and it support HDR. Finally!Same problem with the colour space though.Just updated to 2.04.05 through Google Play:
1. testing with "The world in HDR" video through YT TV app, no HDR indicator on picture menu.
2. By casting YT, I get the HDR indicator on picture menu, but still no max brightness and wrong color space.
Has anyone tried a factory reset to restore the "max brightness"? I was going to but if someone else has and it made no difference I will just live with SDR as its too much messing about.
Can you confirm that Kodi (using latest nightly here) plays VP9.2 at the correct BT.2020 color space? For me it does.
My mistake. It does not. I had 'The World in HDR' in my samples, but it wasn't the original YouTube VP9.2 one, but a transcoded HEVC HDR10 one. So obviously it works.
Sony introduced Oreo in the U.S. with official YouTube HDR support. But unfortunately, color space is still not switched to BT.2020 for VP9.2. What a shame...
Well I just tried in YouTube to play a 4k60HZ vp9.2 HDR video and surprisngly it worked correctly...
Tried on my KD-49XD7005. All settings seem to be correct. Brightness seems ok.
4k HDR Youtube
Oh, you are right. The TV is again picking the VP9.2 stream even with the Nougat firmware. However, it does not max the brightness and wrongly sets color space to BT.709
@Kuschelmonschter wrote:Oh, you are right. The TV is again picking the VP9.2 stream even with the Nougat firmware. However, it does not max the brightness and wrongly sets color space to BT.709
Is the "max brightness" not being set a Youtube app issue or something with the Sony firmware do we think?
Color space and brightness are not set by the app. The TV detects that some HDR content is being playback and sets parameters accordingly. In this case, the TV detects the HDR but fails to set parameters correctly. So it is a Sony issue.
Thats a shame, probably won't ever be fixed then. Interestingly one of my colleagues says that the brigthness "max" sets ok on his XD90 when playing Youtube HDR vidoes now, my XE90 doesn't. Thats why I wondered if a factory reset would fix it, but, don't want to waste my time.
Looking at the "nerd info" on youtube, it seems as it lack some kind of metadata to help the tv identifying the right HDR involved (using AUTO)
I've seen that in one video in HLG and others in HDR10 that manually specifying the right HDR type it works as expected (max brightness, right color space) and the video quality is awesome
@rooobb wrote:Looking at the "nerd info" on youtube, it seems as it lack some kind of metadata to help the tv identifying the right HDR involved (using AUTO)
The metadata is there... This is the metadata info for The World in HDR, downloaded straight from YouTube with youtube-dl. Check at the end the lines in bold (PQ should mean it's in HDR. And BT.2020 is what we are discussing in here):
General Unique ID : 317899792610391996154637148508605156273 (0xEF2945E2B0F883183BC0E0CFEC3C8BB1) Complete name : /Volumes/NAS326/YouTube HDR/The World in HDR in 4K (ULTRA HD)-2160p 60fps.mkv Format : Matroska Format version : Version 4 / Version 2 File size : 341 MiB Duration : 2 min 34 s Overall bit rate : 18.5 Mb/s Writing application : Lavf57.71.100 Writing library : Lavf57.71.100 ErrorDetectionType : Per level 1 Video ID : 1 Format : VP9 Codec ID : V_VP9 Duration : 2 min 34 s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 59.940 FPS Color space : YUV Language : English Default : Yes Forced : No Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant
Also I opened a ticket for the Smart YouTube app, asking if he could force the color space in the metadata. The answer has been negative because... Android doesn't allow to do so. At least that's what he said. So either the Codecs/APIs set the right color space, or we have to change it manually.
One interesting note, though. I did an experiment: I uninstalled the YouTube update, which brang the YouTube version back to 2.02.14 (April 2018) and HDR with it isn't working. I thought it started playing in HDR after the last Android TV update (I didn't check it much anymore because I gave up). So, yeah, it might still be Google's fault, although I am not able to play the downloaded YouTube's HDR videos automatically in BT.2020 either with Video or Plex (I bet Kodi would, but I am not going to install it anymore. Even Plex. just installed now, is literally a slide show. Literally. I mean that the 4K videos stop-restart-stop, especially going into settings to change the color space). Actually plex doesn't even switch to HDR the VP9.2 videos anymore. It worked only with HEVC videos, at least the couple I tested.
Interestingly for me SmartYouTubeTV doesn't work on my XE9005 anymore, when I try and play a 4K video either in 4K Main or 4K Alt I just get a black screen. LOL.
