Hello again!
I assume, there is no possibility to transfer images from Sony NEX wifi to a Nokia Lumia Windows Phone?
Only available for Android and iOS, as that's what the vast majority of the world uses.
If you need apps, you got the wrong phone. Windows Phones are cheap because they are not very good. If you only recently bought it, you might be able to take it back and get something else. Otherwise you are unfortunatly stuck with it.
