Sony NEX, copying images fails, some of the images are not copied to computer
SOLVED
Thoriumi
Hello,
When I connect my camera to computer with USB-cable and copy the images with Windows Explorer (Windows 😎 on some computers (like two of the four I have tested) sometimes the copying dialog just disappears and all the images are not copied. When I try again several times, all goes well. I just have to copy everything many times.
SONY NEX-5R (RL) 1.01
1 ACCEPTED SOLUTION
Accepted Solutions
Bieomax
I'll admit i'm not oh fay with the menu system in the Nex, but in the Alpha's there is a option to change the USB mode, try changing it from Mass storage to PTP/MTP (Picture/Media transfer protocol) and it'll change the way the computer talks to the camera.
i know the computers at work are locked down for using Mass storage on usb, but if i set my A57 to MTP it picks up the camera as actual camera connected device which i can pull images from rather then just a usb drive.
have a play with it and see if it improves the copying of images.
Kind Regards
Mark.
4 REPLIES 4
profile.country.NO.title
photosonic
Enthusiast
Hi Thoriumi !
Have you tried to put the memory card directly into the card reader on the computer ?
Thoriumi
Hello,
Thanks for the reply.
The memory card I'm using is SanDisk 64GB SDXC card. My computer's internal slot doesn't support SDXC cards.
photosonic
Enthusiast
Hi !
maybe an external  card reader can work.
Bieomax
Kind Regards
Mark.
