Hi condurat.catalir, welcome to the Sony Forums
LIke many modern digital cameras, the W510 does not have a date-stamp function. What you see on the built-in screen is only for review and display purposes.
However, assuming you're using Sony PMB to download your photos, you should be able to add a date stamp once the image is on your PC. See the following tutorial for details:
http://support.d-imaging.sony.co.jp/www/disoft/int/pmb/feature/edit/attach_date.html
PMB for the W510 can be downloaded here: http://www.sony.co.uk/support/en/product/DSC-W510/downloads/PMB
Hope that helps
Mick
Hi , can you perhaps give me a model camara more or less the same type that supports timestamp on photos ?
Thanks
Hello @Mick2011,
this is not correct - the camera does support that the date gets saved directly on the image file as described here:
https://www.sony.co.uk/electronics/support/articles/00014743
Maybe this helps you as well @condurat.catalin1 and @Supergeoff.
- Nic
