flashing red light a65 3 short 6 long
I have a A65v that has a flashing red light 3 short 6 long other then that it is dead have recharged the battery and tried another light flashers even when swiched of. :slight_frown:
4 REPLIES 4
profile.country.BE.title
Portmixus
Hero
Have you tried different memorycards? Original battery?
_____________________________________________________
Sony Alpha Training
Thanks for the reply yes I did try other memory cards, battery and even lens. I have sent it in for repair and thanks again and I will let you know the results.
tbischof
I have the same problem.
Any root causes available so far?
beboyle14
when using continuous shooting red light comes on,I THEN HAVE TO REMOVE BATTERY then swwitch back on to start camera again,no shots recorded,any help would be much appreciated
Tags (1)
